Charlie_D_'s avatar
Charlie_D_
KIB Tank Monitor
We have a KIB M28 tank monitor that does not light up when I push the battery monitor button. All other button work. I checked the converter and all is well with it. Checked the battery and it is fully charged. I pulled it open and checked the connections which plug in but no help. Any ideas.
  • j-d's avatar
    j-d
    Explorer II
    Good enough!
    Thanks for the update. Keeps us from wondering!
  • Update: Opened back up and removed circuit board again. Pushed and wiggled button and light started to work. Still working after reinstall. Evidently it was not making good contact.
  • j-d's avatar
    j-d
    Explorer II
    KIB has troubleshooting on their website. They also offer phone tech support.
  • I had a led burn out in mine one time. Does the momentarily closed switch have continuity when pressed? Tracing 12v up to and through the switch and LEDs is to horribly hard if you already have had it open and checking connections.
    Jim
  • Tanks indicator work fine. The light indicator for the "battery" does not light up. This light shows the charge state of the battery.
    Which tank?
    Jim
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
