westend
May 14, 2013Explorer
How are you measuring that voltage from the panels? Something doesn't add up, if the diodes on the panel were burnt open, there would be zero output.
I thought that RV wiring convention as to color was always: black--hot, white---ground? Good on 'ya for marking the wires, anyway. I would bet that the spark you encountered was the result of the reversed polarity at the battery. that may have affected the controller but doubtful any power greater than the panel's nominal voltage was exceeded or overcame a diode.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
