pondputz
May 14, 2013Explorer
On the back of the panel. there should be a panel or box that houses the diodes,
Access the diodes, check them with a ohm meter,(a diode will let power travel in one direction not the other).
Using the meter leads, place a lead on each end of the diode, and observe what happens, reverse the leads, observe what happens,
You should have continuity on one connection and not the other, if you have no continuity in either test the diode is blown.
Putz
Putz
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
