TomG2
May 07, 2018Explorer
Killer Amps
I want to pull ten amps out of a little 35 ah battery for one hour and then fully recharge. Will this heavy draw destroy the battery? I know it is a small battery.
TomG2 wrote:A lot more than 100w.
How much heat do I need to make a camper shell a little warmer on a sixty degree morning? Not much.
TomG2 wrote:
How much heat do I need to make a camper shell a little warmer on a sixty degree morning? Not much. I am not trying to heat a house. I am more concerned with the effect on the battery than on whether it will warm me up or not.
wa8yxm wrote:
at this battery size I ahve to ask if it's a AGM or liquid. (LIquid would be like a garden tractor battery or motor cycle, though if I had a cycle that is one place I'd use AGM)
I woudl say try it. draw your 10 amps for an hour (10 amp horus) let it sit for like 20 mintues and measure voltage.. If it's too low add more battery
if it's still at say 70% recharge
NOTE: for batteries other than DEEP CYCLE 70% is too low. DEEP CYCLE (Golf car mostly) can go to 50%, but Starting batteries and MARINE/Deep cycle should never drop below 75-85% depending on the battery so you are likely doing damage .
You can also google the Effect (purket? Someone mentioned it above) and find some calculators that may help you find your discharge level.
TomG2 wrote:valhalla360 wrote:
What are you trying to accomplish? Might be easier to simply add a 2nd battery.
Run a 100 watt heater off an inverter. my inverter has a low voltage shut off, so I might give it a try. Only out $70 if it won't then I can get the 100 ah battery that I really need.
