RCtime
Aug 23, 2014Explorer
Kinda dumb valve stem extender question
The extension that screws on to your inside dually that extends to the outside dually so you can check the air pressure/add air etc.
Does it have one long valve core in that presses down on the valve core of the inside tire?
Why my interest? While checking my air pressure the other day, while removing the cap, the whole extension rotated. I tightened it and continued my air check. But just wondering as the extension looked as if a normal valve core was installed.
Looking between the duallies you can see its just screwed on to the normal valve stem.
the inner dually on mine was perfect at 100# even though the extension was loose.
