rickhz's avatar
rickhz
Kitchen faucet issue - Integrated flex copper supply line
I went to replace my kitchen faucet only to be stopped in my tracks by a mismatched setup. The old faucet uses flexible copper supply lines which are brazed into the faucet end and have a male connector on the other end.
The female connectors off of the PEX will not reach the standard style faucet with two separate inlets.
I have not been able to find a replacement faucet that matches what I have. I would really like to find an exact match so I don't have to cobble the system together.
I would be happy with a short extension hose that has a male on one end and a female that would attach to the faucet on the other.
Any help would be appreciated!
  • fj12ryder wrote:
    What's wrong with 3/8" for bathroom/kitchen faucet? All of mine are 3/8".
    From my experience it assumes household water pressure, not the 40psi you find in an RV. Sorta like needing bigger cable for 12v.
  • What's wrong with 3/8" for bathroom/kitchen faucet? All of mine are 3/8".
  • fj12ryder wrote:
    .. the more expensive ones, are coming with the attached water lines.
    Which are all 3/8". Grrr
  • We discovered when searching for a replacement faucet for the toyhauler that most faucets, especially the more expensive ones, are coming with the attached water lines. We spent a lot of time trying to find one that just had the short hard line that attached to a water line.
    Nothing on Amazon?
  • I don't like what you have now because if there is ever a problem with the supply line the entire faucet has to be replaced. If you try to attach a supply line and accidentally twist the copper it's all over.
    I'd much rather have the short inlet pipes which are very sturdy. I agree with the idea of buying what works well for you above the sink. The below stuff is one time. The above stuff is every day.
  • Buy the faucet by the look and function above the sink.
    Then get what you need at Home Depot and connect.
  • You already have a cobbled mess, RV manufacturers do that.
    Cut the PEX pipes down low, install shutoff valves, then run standard faucet supply lines like they do in a properly built house.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
