- markchengrExplorer IIThose are called tubing wrenches. Anyone who works professionally with tubing uses those. They come in sizes for all the common flare or compression nuts. Mark.
- MEXICOWANDERERExplorerAt one time I had a reinforced 7/8" not-quite box end wrench for POL line fittings. 12-point with some of the points missing to pass the wrench across the propane line. It sure lessened the destruction of the brass fitting's corners.
- LwiddisExplorer II"a lifetime guarantee refers only to the lifetime of the company"
And/or the expected "lifetime" of the item. Not your lifetime. - fj12ryderExplorer IIIYeah, water-pump pliers have their place, but it's in addition to a crescent wrench rather than a replacement.
A well built crescent wrench will have parallel jaws at any position, with little, to no, extra movement of the jaws.
Of course a good mechanic will tell you that there's no place for a crescent wrench in a well equipped toolbox. :) - mike-sExplorerThose are nothing like a Crescent wrench, which holds its setting without user effort. Those are parallel jaw pliers, and are nothing new. Wiha (#32635) and VBW (PowerGRIP) make similar.
- obgrahamExplorerNot so sure. I've had a few "improved" crescent-style wrenches over the years. Most of them didn't work as well as the original. One even had a battery in it to screw the jaw closed. Bah.
I like my Craftsman adjustables. Never the best choice for a wrench, but often the handiest. - LittleBillExplorercan't say i love them, the heads are smaller which is nice, but the adjustment takes time, and you have to apply pressure to keep them close.
the set below was like 8 bucks, and are one handed and generally don't round off either.
Clicky - 2oldmanExplorer IIAdjustable jaw open-end wrench. Crescent is a brand name.
- TakingThe5thExplorerI’ve learned the hard way that a lifetime guarantee refers only to the lifetime of the company, and any reorganization can also upset the apple cart. But it does look like a nice tool.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
