MEXICOWANDERER's avatar
Nov 20, 2018
Knipex Improvement On The Crescent Wrench
Like any top quality tool this sucker ain't cheap at $50 but then neither is gasoline or postage to exchange lifetime garbage.
  • Those are called tubing wrenches. Anyone who works professionally with tubing uses those. They come in sizes for all the common flare or compression nuts. Mark.
  • At one time I had a reinforced 7/8" not-quite box end wrench for POL line fittings. 12-point with some of the points missing to pass the wrench across the propane line. It sure lessened the destruction of the brass fitting's corners.
  • "a lifetime guarantee refers only to the lifetime of the company"
    And/or the expected "lifetime" of the item. Not your lifetime.
  • Yeah, water-pump pliers have their place, but it's in addition to a crescent wrench rather than a replacement.
    A well built crescent wrench will have parallel jaws at any position, with little, to no, extra movement of the jaws.
    Of course a good mechanic will tell you that there's no place for a crescent wrench in a well equipped toolbox. :)
  • Those are nothing like a Crescent wrench, which holds its setting without user effort. Those are parallel jaw pliers, and are nothing new. Wiha (#32635) and VBW (PowerGRIP) make similar.
  • Not so sure. I've had a few "improved" crescent-style wrenches over the years. Most of them didn't work as well as the original. One even had a battery in it to screw the jaw closed. Bah.
    I like my Craftsman adjustables. Never the best choice for a wrench, but often the handiest.
  • can't say i love them, the heads are smaller which is nice, but the adjustment takes time, and you have to apply pressure to keep them close.
    the set below was like 8 bucks, and are one handed and generally don't round off either.
    Clicky
  • Adjustable jaw open-end wrench. Crescent is a brand name.
  • I’ve learned the hard way that a lifetime guarantee refers only to the lifetime of the company, and any reorganization can also upset the apple cart. But it does look like a nice tool.
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
