Just replaced the step motor and module on my 2000 Monaco Windsor(A arm single step)and also new 4-way plug.The only way to make the step work is unplug the Brown wire to the 4-way,step extends plug b...
The new ones work differently than they used to- the door switch is reversed- yours is normally closed, the new requires a normally open one- a new switch should have been included in the kit. As well the main "power" switch works more or less backwards.
Having RV issues? Connect with others who have been in your shoes.24,277 PostsLatest Activity: Jul 02, 2025
