3708's avatar
3708
Explorer II
Sep 12, 2014
kwikee step issues
Just replaced the step motor and module on my 2000 Monaco Windsor(A arm single step)and also new 4-way plug.The only way to make the step work is unplug the Brown wire to the 4-way,step extends plug back in step retracts.They give you three test to check your 4-way plug it passed the main power source, the step switch,but failed the door switch test i have 12.5 between brown and red when door is open and when door is closed but remember these test are done on the power side of the plug. I've checked fuses step and motor, checked entry step switch, checked magnet on door jamb. Throw me some ideas, i'am leaving in a week if push comes to shove i will unhook the brown wire when parked so i have a step, but i would like to get to the bottom of it. Thanks 3708
  • 3708's avatar
    3708
    Explorer II
    fischer i agree, and i do have the owner's manuel #888. but what puzzel's me is once you unplug the 4-way you have now isolated the step, doorjamb magnet switch, entry step switch, power module everything to do with that step from the vehicle side, excuse me the entry step switch does get power from vehicle side prior to the 4-way but i changed that with no luck.:h
  • Search kwikee electric step troubleshooting and select ,,PDF electric steps
    pg 7 has how to test the step functions without the motorhome wiring good l
    after looking at the guide , it says you should have
    12v from red to brown with door closed
    0 v. from red to brown with door open
    so the door sw is bad or the terminal connections or magnet misaligned
    you could try smacking the door sw
    I have a step switch that stops the door sw from working when parked if you have that sw maybe you. have it in wrong position.
  • When I had my problem it turned out to be the door buttons that cause the step to go out and come in. If you replace it make sure you stick with the same colour. I don't know why but I was told that when I bough mine.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
