3708
Sep 12, 2014Explorer
kwikee step issues
Just replaced the step motor and module on my 2000 Monaco Windsor(A arm single step)and also new 4-way plug.The only way to make the step work is unplug the Brown wire to the 4-way,step extends plug back in step retracts.They give you three test to check your 4-way plug it passed the main power source, the step switch,but failed the door switch test i have 12.5 between brown and red when door is open and when door is closed but remember these test are done on the power side of the plug. I've checked fuses step and motor, checked entry step switch, checked magnet on door jamb. Throw me some ideas, i'am leaving in a week if push comes to shove i will unhook the brown wire when parked so i have a step, but i would like to get to the bottom of it. Thanks 3708
