dougrainer
Feb 13, 2019Nomad
There are 3 types of step switches and they do NOT have to be magnetic.
1. The standard Magnetic switch installed on the metal door frame with the self adhesive tape
2. The Magnetic ROUND switch that is installed in a 5/8 hole drilled into the door frame with the other magnet drilled and installed into the door to match the frame switch
3. The NON magnetic standard PIN switch installed in the hinge side door frame. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
