randco
Feb 13, 2019Explorer
Thanks for the quick response. To clarify... I am trying to locate a switch that makes the stairs retract when the ignition is on and the door is closed.
My door has either 4 or 5 plunger type contact "pins" on the hinge side of the door that align with copper or brass "pins" on the frame. I suspect at least a couple of the "pins" are part of the auto door lock when the coach is taken out of Neutral.
