garym114
Feb 13, 2019Explorer II
The steps have a main operating switch. On position operates the steps based on the door position only.
With the main switch in the on position and with the door open you can find the magnetic switch by using a magnet in in your hand and moving it around to suspected magnet switch location.
The same magnetic switch is used to operate the steps with the main switch on or off. Off position makes the stairs retract when the ignition is on and the door is closed.
