dougrainer
Feb 13, 2019Nomad
randco wrote:
Thanks for the quick response. To clarify... I am trying to locate a switch that makes the stairs retract when the ignition is on and the door is closed.
My door has either 4 or 5 plunger type contact "pins" on the hinge side of the door that align with copper or brass "pins" on the frame. I suspect at least a couple of the "pins" are part of the auto door lock when the coach is taken out of Neutral.
Most door electric lock systems the door hinge side plunger pins there are only 2. Even with the Brake system. So, if you have 4 pins, the other 2 pins are the ground to and from the door to the step control. To determine, electrical tape the 2 top pins and then close the door. See if the Auto lock works. IF IT DOES NOT, those 2 pins are the step switch pins. IF IT DOES, the bottom 2 pins are the Step switch pins. What makes you think the Step magnetic switch is your problem? Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
