olygene wrote:
Thanks for a great post -- the pictures and procedures were awesome. My Kwikee step motor is giving me some trouble and I would like to replace it, but how did you find that a Taurus window motor was the right replacement? Do I have to remove the current motor and take it to Napa and just eyeball every window motor they have to see which comes closest? Is there a parts # on the Kwikee motor that provides a clue? Anyway, thanks for a very informative and helpful post.
I had seen a post on here from bsinmich he said that he replaced his with a lincoln window lift motor and gave me a part number. I decided to check the NAPA site, I had the motor out already and was able to look at photos on the NAPA internet site entering years, make and models I looked at the different photos, now it is important that you order the left front motor because the right lift motor the gear housing is oriented opposite from the left front lift. And the rear is different also. The Taurus being one of the high volume models Ford made makes it a great cross over part. If you think of it Kwikee is quite smart about it, the part being made for a very popular model car makes the part readily available for their used in the steps. Whenever, you have to have a part made specially for you the cost is quite high unless you do it in volume, if you use parts that are easily obtained because of it's other uses as the Taurus then you will have always have parts available instead of having to order them in mass quanities.
After finding that the motor looked the same, I orded it through Auto Zone, I asked them if I could return it if it was not the right one. They told me no problem. By ordering the Auto Zone they offered a lifetime warranty on the motor, and at a cheaper cost at 49.99. If the motor goes out again, I will have the warranty to back me up.
