r1chy
May 03, 2008Explorer
Ozarkwoods wrote:
r1chy,
Thanks, now also you might want to make sure this will work for your motor some with newer steps have said they have changed motors...now with that said it could just be another window motor from a different make and model. Or their own motor. I suspect it's a motor readily available. Just an FYI.
Ozark - Point well taken and thanks once again for the photos, which should help determine if mine is the same.
Soooooo, what else have you done that is equally well documented?
R1chy
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
