Had some problem. The issue for me was the plastic gear that works with the worm drive was worn out. Plastic gears in theis situation are never going to last very long. If you could find a replacement gear this could be reapied cheaply but I had no luck find a replacment.
I found the following lift motors that will all work as replacments:
http://www.napaonline.com part # BK 6551518 cost as of today $92.49
http://www.autozone.com
Dorman part # 742-241 $83.99
Cardone part # 82-3003 or 42-3003 the 82 is new at $109.74. the 42 reman at $52.99 after you return the old motor
Parts Perfect # 73096 $81.99
If you google the above products you can find lots of info. about them.
My original motor was made by AM Equipment a 214 series see http://www.amequipment.com/06_window_lift_motors.html
I'm going to try the Cardone reman one since it claims to have an improve worm gear mechanism which is where my last one failed. That and it is the cheaper option.
