I dont quite understand the origional post. The pictures listed for the "New" matching motor do not jive with the part numbers listed. If you go on-line to Napa or Dorman the Ford Tarus parts for the model years you listed do not look like the new part you said you ordered. In fact if you order the Tarus part, the electronics have a vent hole that is not sealed (not good in water under the rig), and the body is fatter than the origional so your not gonna get a great fit. I also verified this by pulling three motors off Ford Taruses at pick and pull. They all match the Napa Pictures for Tarus parts you listed but do not match the "new" picture in your photos.
http://www.napaonline.com/NOLPPSE/(S(tiq22pavj3yf0j2blpb5fnv2))/Detail.aspx?A=BK_6551395_0158097603&An=599001+101995+50026+2026029
So what gives? What part did you really order? Post a link to auto parts store picture that looks anything like your photo.
The one that does appear to be the match in the 1992 Lincoln Contential right rear window lifter. But good luck trying to get that one out of the rear door at a pick-in-pull. I just dont understand why you think Tarus is a match......see link above.
