Randy good idea I will start a new post with pictures for the newer steps. IMHO I don't think they improved much between your 1995 steps and 2005 ones. Everything looks the same as in your photo's. The only change appears to be a new electornic controller unit and then using a different motor. It appears they just changed to a new version of the lifter motor since it looks very similar to the one in your photos probably at the same time Ford change to a new version of the motor. I don't know if it is still the case but car manufacturers used to run on a 10 year life cycle so Ford would be changing this motor every 10 years or so.
Anyhow come this weekend I will document using the same format Randy did in the original post.
