When My Kwikee Steps Motor stopped working, it was easier to pull the Motor and Gear Box as a single unit! Surprise the Thing said AC Delco on it! Now AC Delco Is or Was a General Motors Product. I'm was pretty sure that I Had seen one of these Motor/Gear Boxes before so I took a trip to a nearby Auto Wrecker. As soon as I set the thing on the counter the Manager said "That Looks like a Ford Window Lift! I Said it says AC Delco on it. He Looked and muttered "So It Does" Then we set off for the "Parts Bin" Sure enough All the Left Hand Ford and the Left Hand GM Window lift Motors were the Same! There were a few slight differences in the Gear Boxes but All could be Modified by grinding down a bit of metal!
So before narrowing what You have down to a Taurus and Buying "New" Check out the Local Auto Wrecker for Just about Any Window Lift Motor, Left Hand for sure , but Either should be workable if you switch the Power wires! Oh Yeah About $20 should do it!
