965Racer wrote:
rad valve wrote:
Kwikee will not have that high torque motor they have not used that motor for a couple years. The AM equiment motor took it's place.
I pulled the motor today. The AM motor would be great, but there's a problem. The AM 214 is definitely the right size, thickness, etc., but the hole pattern for mounting is the 11 degree type that the smaller AM 210 motor uses, not the higher degree version that the AM 214 uses. So I need the hole pattern of the 210, but the torque of the 214. Weird.
Any further suggestions?
You mite neet to get the newer chinese gearbox to go with that motor
the new Am motor 214 don't fit the old gearbox. You could check
napa or some other auto parts stores to see if they mite have
the high torque motor the hight torque sticker on the motor was a kwikee sticker not from the maker of the motor.
That power window motor is a siemens.
Numbers on the motor 091604 12v 4a 127169 Hope this helps.
