MopaRV wrote:
With this great info from Randy and others,( thank you ), I got excited because I also needed a new motor. Went to the pick-a-part and bought window motor off a '95 Lincoln. Got home and OOPS, motor doesn't match. My mistake. Oh well. (Learned later the motor needs to be off 88-93 Lincolns)
Went back to pick-a-part and bought the motor off of a '93 Taurus. Brought it home to find out this one won't work either. The linkage cover doesn't fit properly over the backside of the motor gearbox. Different design. The motor, I noticed later, is a Denso Japan. The design looks like the remanufactured motors I looked at today at CSK auto. My luck.
So I decided to go to Autozone to maybe just buy a new one. They pulled it out of the box. ITS PLASTIC. Made in Korea. YIKES! No thanks.
Couldn't get the images to work...
I learned a lot, but I'm back where I started. LOL
Kwikee used several different designs. My steps were on a 96 Coachmen. Depending when yours were made. Bring your old motor in and compare it. The front drivers door window motor on a taurus worked for me. Too bad the photos are not working for you. you will see just how close I matched the motor. Now try Napa, and other parts stores or go to the Dorman company site they all deal with different suppliers. Matching in person works better than anything. Hope this works for you . Wow over 11,000 views I wonder what the record is?
