folivier wrote:
I have Kwikee series 32 made in 1993 steps. The large metal gear in the gear housing had a couple broken teeth. I ended up turning the gear so that it uses the other side and it is working for now. \\
I sure would like to find a new METAL gear. I really hate the thought of having to pay so much for the conversion kit from Kwikee that has the plastic gears.
anybody ever found the gear or gear case assembly?
This it the company that made the gear boxes and linkages and gears for Kwikee I don't know if you can get parts from them.
http://www.henrymfg.com/default.asp?active_page_id=1
