C-Leigh_Racing
Feb 02, 2012Explorer
That three way switch sounds good.
One 12V hot wire with a jumper wire hooked to the other switch side & then two wires from each switch side, then all four wires running from the switch to the motor connector plug end converted down to two wires.
Walla, overide switch doing away with that crazy control box & D/H will get a little recongnition boost from on looking thinking hes opening the door like a gentelman & helping D/W out of the M/H.
Neil
Neil
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
