What I was thinking, like if your inside the coach & cant see the steps, if they are in or out, those micro switches & little light would let you know when to release the toggle switch.
The step controller box, has a function to tell when the step motor is under load once the steps stop moving & turns the 12V off to the step motor.
If you hook up the manual switch, & have nothing alerting you the step motor has stopped moving & keep holding the toggle switch, you'll soon over time burn the step motor up.
Was just an idea, maybe a bit to much or over kill I guess.
Neil
