C-Leigh Racing wrote:
What I was thinking, like if your inside the coach & cant see the steps, if they are in or out, those micro switches & little light would let you know when to release the toggle switch.
The step controller box, has a function to tell when the step motor is under load once the steps stop moving & turns the 12V off to the step motor.
If you hook up the manual switch, & have nothing alerting you the step motor has stopped moving & keep holding the toggle switch, you'll soon over time burn the step motor up.
Was just an idea, maybe a bit to much or over kill I guess.
Neil
Ahhh.. I understand now..
That might actually be useful then..
More useful though, might be something to kill the 12V to that motor in case you forget to turn it off..
For me.. I'm just happy to have a cheap fix for that broken control unit--
