Clay_L
May 23, 2012Explorer
etmorrison wrote:
Help, my Kwikee series 32 wont extend so I can check the motor and gears. Is there a way to release the steps. I tried direct connecting a 12 battery on the Yellow and Red wires and reversing them just in case, but just sparks and clicking.
This puppy is retracted and tighter than a drum even with power off
There is a pin that holds the extending/retracting arm to the step. If you remove the hitch pin from the retaining pin and remove the retaining pin the steps can be manually extended or retracted.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
