Audioa_fan's avatar
Audioa_fan
Kwikee Step Problem
I am a long time pop-up camper that just recently took the huge step up to a class A. I purchased a 2001 HR Ambassador from some wonderful and helpful folks. I was attempting to solve a problem with the Kwikee step power switch at the entrance door. The 7.5A power switch fuse was blown. When I replaced it, it immediately blew again. I investigated and found that the motor power switch at the entrance door was mis-wired. I corrected the problem and replaced the fuse again and the light in the switch started working and the step light came on. But the steps would not retract. But I could hear a relay click in the controller. And a new problem, now the ignition switch would not retract the steps either. But again, I could hear the relay clicking.
I have read several posts relating to issues with Kwikee steps as I attempted to diagnose this problem with mine. I spent considerable time studying the Kwikee schematics, the HR wiring diagrams, and making voltage measurements on both the motor cable and the 4 way Molex connector at the controller, and everything looked perfect. I was at a loss for what the problem was. Then I realized that what I was hearing was actually two rapid clicks. The relay was closing and immediately reopening. That realization led me to understand that the controller was sensing overcurrent and turning off as soon as it turned on. Turned out to be the coach batteries were a little low at about 11.2 VDC and the motor couldn't start and that caused the current spike that the controller interpreted as the mechanism reaching the end of travel. I suspect the brushes on the motor are well worn and need to be replaced. But as a new RV'er, I learned a valuable lesson about how to interpret the coach battery level meter. Two lights out of four is not very good for operating anything except for lights.
1 Reply
  • I've encountered the same thing with mine when the engine battery was low. If your steps are like mine the clicking you hear is a bi-metal thermal switch inside the motor. The motor is a car power window motor. The thermal switch is used to cut power when the steps reach the fully extended or retracted position. Too much current and the switch opens, the controller senses no current flow and it cuts power to the motor. Only takes a second or so for switch to cool and close then the steps can be operated in the opposite direction.
    Your diagnosis is pretty accurate. The low voltage from the battery causes the motor to draw too much current and opens the thermal switch.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
