I have a kwikee step with a round megnetic door swith.I noticed that if i move the switch around it would activate the step.I took the switch completely out of the door frame.If i move the wires aroun...
Yes you can replace that device .. sold at any RV dealer/supply house. That magnetic switch connects to the door switch .. before you replace I would try and insure that the door switch is OK as well as the wiring between the two device. Lastly .. make sure you batteries are OK as Kwikee steps are known to open/close and otherwise act erratically when the batteries get too low.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
