j-d
Mar 08, 2016Explorer II
Some of those motors can be replaced with Ford power window motors. That gets the cost down into the $50 range. Of course everything else needs to be good or repairable/repaired. It's been discussed here, so a search should turn it up.
Gearcase can be salvaged with a kit from the HELP rack at the auto supply. If the motor is round, pretty easy to clean up and get running. The square-form ones seem quite a little trickier.
EDIT: Chris posted his gearbox repair link while I was typing. That HELP 74410 is the kit I was referring to. I first learned about this at an auto supply that pressed a lot of wheel bearings. Guys would get balls from junk bearings and use them as the "Kit."
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
