Almot
Jun 17, 2016Explorer III
Geterdone wrote:
I went thru diagnostics with volt meter and panel only produces 9.47 volts.
You can only be sure of this if you measure it directly on the connector box at the back of panel.
As noted, there are probably no fuses before controller. (And if there are fuses and they blew, there shouldn't be any volts on the controller input terminals).
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
