DFord
Nov 25, 2019Explorer
YouTube video: Installing RV Water Heater Bypass For Winterizing The video shows a one valve bypass which relies on a check valve in the water heater outlet. There are 3 valve kits without check valves that work just as well. The check valves are problematic and are known to come apart of block the outlet.
Even after bypassing the water heater and draining it, it's important to blow the rest of the lines out really good to prevent water from collecting in the low spots.
