schlep1967
Nov 25, 2019Nomad
A few thoughts if you are not adding a bypass right now.
Drain the water heater. With the drain still open blow air through the lines. This will clear the "before" side of the water heater blowing it into the water heater and out the drain. Put the plug or anode back in place and blow again opening one faucet at a time. This will clear the "after" side of the water lines. After doing that I would remove the plug/anode again just to allow any residual water to drain.
