Ivylog
Aug 13, 2013Explorer III
I'd start by putting a jumper cable straight to the motor and see how fast it runs as often the size wire is too small. 25 amps is barely enough to run this size motor and if you have a large voltage drop the amps needed go up. Larger wire and/or a 50 amp breaker will solve the problem.
