westend
Oct 19, 2015Explorer
Onboard or standalone charger? What make and model?
This newer 36V Lester charger has a separate "storage feature" (floats), otherwise it turns off.
This newer Onboard Lester charger has the same storage feature.
Many older chargers never turned off. Some turned off when the batteries reached a certain voltage set point sensed by the charger. If you have an older, unknow functionality charger, it would be best to monitor the charger to see what it does after the batteries are fully charged.
If you are messing around with golf cart chargers and batteries, you need a hand held multimeter. If you own an RV, you need a hand held meter. If you are alive and want to find out anything about the hundreds of electrical items you own, you need a hand held multimeter.
