John_Joey
Oct 20, 2015Explorer
Almost forgot. If that EZ-Go has a run/tow mode switch under the seat make sure you put it in tow mode. If it was in run mode that might explain why your batteries were dead after 3-4 months of nonuse.
If the batteries are good they should last 3-4 months if you disconnect them like I posted prior. No different then if you left a car with the negative cable off. But I do know batteries like cold not heat so your conditions may be different then mine.
On edit:
If you do have a run/tow switch make sure you're in tow mode before you disconnect anything.
On edit:
