dclark1946's avatar
dclark1946
Late 80's RV Questions
I have offered to consult with a young couple in our neighborhood that just purchased a late 80's Class C motorhome but have no previous experience with RVs. All my experience is with TTs starting with our first new one purchased in '99.
After meeting the couple, doing initial RV checkout and going over some of the basics with them, I have a few questions.
The range and oven function but I was puzzled that the oven control had a pilot position but you did not have to push the temp/pilot knob to light the pilot while waiting for the thermocouple to heat up. The pilot lit and the burner operated when rotated past the pilot setting.
The house battery is in the Ford van engine compartment on the driver's side but only measured 7 volts (engine off) while the engine battery on the passenger side measured 12.5V. The house battery was getting charged once the engine was started but it is going to need replacement due to age and state of discharge. How is the house battery typically isolated from the engine battery when the engine is off? The coach battery monitor read "all lights on" but the LP detector correctly had a low voltage light on. Both should have read low battery with engine off. Is it possible that the coach battery monitor was measuring the engine battery rather than the house battery?
Thanks,
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
