tenbear
Sep 19, 2014Explorer
If you can put the shunt in the negative lead of the battery, then the "hot" wire would only be milli volts above ground. Shorting it to ground would not be a problem. Of course, if the shunt would open up then all the current would flow thru the meter wiring. A good reason to put a fuse in the "hot" meter wire.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
