RoyB
Sep 19, 2014Explorer II
TENBEAR - Thanks... I would have to rewire my battery bank scheme a tad to do that but is doable... I have all of my battery switching in the POSITIVE SIDE of each battery and the NEGATIVE Lead of each battery goes straight to FRAME GROUND. I would have to use a TERMINAL BLOCK arrangement to run thru a NEGATIVE TERMINAL installed shunt to a single frame ground point.
This is my current battery bank setup with my HALL EFFECT SENSOR in the POSITIVE SIDE of the selected batteries thru the switch arrangement
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
