dougrainer
Jan 10, 2019Nomad
On LCI systems the culprit is the Pressure switch. There is just the ONE pressure switch that determines when the jacks are retracted. Usually the switch is just BAD, but replacing it will usually fix the problem. Doug
https://www.lci1.com/assets/content/support/technical-information-sheets/Leveling%20and%20Stabilization/CCD_0001900.pdf
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
