dougrainer
Nov 18, 2018Nomad
reppoc12 wrote:
Many thanks to all I appreciate the help. I read that part about emergency jog mode and tried pressing it multiple times with no success. As suggested it looks like I will need to pull the motors. Looking at the trim I need to remove to get in there concerns me as all the "star" screws look stripped. Well, I spent today working on installing an auxiliary fuel tank in the truck, so back to the slide tomorrow.
Thanks,Rob
Your comment about the stripped screws shows you are not knowledgable about the Jayco install. You have a 2 year warranty. Is the unit out of warranty? The screws are unscrewed and screwed in with a No. 2 square bit. The screws do not look like square bit screws but the No. 2 will engage and unscrew. There should be NO such screws to remove to disconnect the Schwintek system motors. Doug(Jayco dealer Technician)
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
