pianotuna
Sep 26, 2015Nomad III
Thanks Mex,
That gives me a place to start. As always you are cogent and encouraging.
I'm finding that 3 amps appears to be the magic 0.5%. That is easily accomplished by the solar system. I'm not 'seeing' 13.2 volts @ the 0.5% but rather 13.6.
I have not adjusted the float voltage on the Blue Sky controller yet.
Since I had the new bank installed I've not seen the 'float light' on the Blue Sky. How ever I do see 13.6 with the 'absorb' light displayed which is bang in the middle of the suggested 13.4 to 13.8 float zone.
The bulk voltage from the Blue Sky is 14.6 on the display--but not on the volt meter which shows 14.3 to 14.5.
Given those numbers I'm not sure I will bother to change the float voltage on the Blue Sky.
The RV goes into storage on November 14 and stays there until March 10th, 2016.
I'm loving being able to use the load support feature of the Magnum inverter which the old worn out flooded batteries could no longer power.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
