pianotuna
Sep 27, 2015Nomad III
Once the acid is 'used up' positive plate erosion or shaling stops. So by being acid starved the cycle life of the battery bank is some what protected. This happens at the expense of total available capacity, in the short term.
The other side of the starved acid is that any equalization (called a conditioning charge) had better be done by approaching the gassing voltage but not ever exceeding it. In the non starved that is a tiny bit less of a concern.
brulaz wrote:MEXICOWANDERER wrote:
Those batteries are engineered for prolonged life in standby mode with safeties built into battery maintenance mechanisms not in the inherent design of the battery itself. Total prolonged discharge will damage this type of battery a lot more than an acid starved type.
Not to highjack the thread, but would "regular" commercial AGMs like Lifeline, East Penn, Rolls be the acid-starved type?
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
