joebedford
Jan 04, 2023Nomad III
CarnationSailor wrote:
Why did the manufacturer replace everything?
The broken spring PLUS the broken hanger PLUS two blown tires PLUS two bent axles PLUS the fact that the same model our year +1 had heavier everything. I think we went from 5000lb axles to 7000lb (+ wheels, tires etc.)
I guess they realized that even though they were within spec, they would be spending too much on warranty repairs.
No, my RV wasn't overloaded.
I eventually replaced that TH with a tri-axle model. Only suspension problem since was a broken spring bolt on the rear hanger (both ends were still there but it was snapped inside the spring loop).
