CarnationSailor's avatar
Jan 03, 2023
Leaf Spring Failure - Replace the Others?
Last summer I experienced a leaf spring failure on my 2015 Crossroads Rushmore Springfield. The driver's side rear spring snapped in two about 2-inches from where it attached to the frame. After being alerted that the tires on that side were rubbing together, I pulled to the side of the interstate. I had just entered the highway about a mile back, so I was lucky to discover it so soon, and there was no damage to the tires or the trailer. I was very lucky!
AAA got me to a nearby RV repair shop that happened to have a used leaf spring off of a 7000# axle, and it fit my trailer (My axles are 7000# too.) The used spring that was installed appears to be heavier duty than the one that failed. The used one has 7 leafs and each leaf is about 3/8" thick. The one that failed has 6 leafs and each leaf is about 11/32" thick. (1/32" thinner.) Both springs are about the same width.
The tech that installed the used spring recommended that I replace the other 3 leaf springs with heavier duty ones when I got back home. Although the episode could have been a lot worse, I still wouldn't want to go through it again.
Should I replace them, or just consider this event to be an unusual occurence that is not likely to happen again?
