ENG2242ExplorerJun 25, 2022Leak near Valve/Tank ConnectionI have an occasional/slow leak at the Tank/Valve connection. This is the black tank, and it seems like the pressure vent is not releasing pressure, as this only happens whilst the tank is 3/4 full and...Show More
2112Explorer IIJun 26, 2022Use This to post picturesEven if his vent pipe is too far down inside his black tank it shouldn't leak. Fix the leak.It could just be the weight of the water causing it to leak at a poorly sealed joint. Fix the leak
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 07, 2026
Related ContentNautilus P1 has leaking connectionsQuick connect exterior shower hose doesn't connect.Black tank valve leakingHolding tank valve leaksBlack tank valve leak
