I have a radiator coolant surge bottle which is made of some type plastic. There is a brass fitting which screws into the top with a small tube connected to it with a clamp. The brass fitting has a ...
The tank is only 1 year old and I don't believe it is cracked. In fact the reason I reseated the fitting was because it was too loose. Since the tape did not work, I thought there may be a gasket sealant. Maybe JB Weld or something I could use instead of tape.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
