I have a radiator coolant surge bottle which is made of some type plastic. There is a brass fitting which screws into the top with a small tube connected to it with a clamp. The brass fitting has a ...
Thanks Gjac. I don't have an obvious crack in the tank. My concern is whether I may have over tightened the brass fitting which created a small seepage around the threads. My question is whether the Goop or JB Weld will seal this seepage.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
