EncoreExplorerApr 21, 2015Leaking BottleI have a radiator coolant surge bottle which is made of some type plastic. There is a brass fitting which screws into the top with a small tube connected to it with a clamp. The brass fitting has a ...Show More
Tin_PusherExplorer IIOct 29, 2015Use real pipe dope. I generally use Teflon tape only when I don't care if it leaks or not :)
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
Related ContentWatch My DeGas Bottle Blow CoolantColeman Propane BottlesI installed the Mishimoto Degas BottleLippert faucet leaks, replaced with MoenMishimoto and FORD OEM DeGas Bottle Comparison
